[Action Flow] Empty popup when click a data field in Action Flow module
  • Aug 5, 2022 3:52 AM UTC
  • 185 views
For example, as shown below, when you click a data field, a popup with choices should have appeared automatically.
However, I get an empty popup from today's morning (JST 9:00).
Could you tell me why this happened?
action_flow_error
Yours,
Chen
Hi @claire.chen12,
Did you see values in this field before? If yes, it might be a temporal failure and you could report it using a service request (I don't think they monitor the Celopeer Posts).
If not, be sure that you connect the previous nodes with the required data format so that it will pop-up here.
Forum|alt.badge.img+28
Hi @claire.chen12,
  • Aug 8, 2022 2:40 AM UTC
Thank you for your answer!
