Action flow doesn't sum amounts correctly - how to fix?
  • Jun 30, 2022 7:53 AM UTC
  • 179 views
Configured the action flow to send an email where it would summarise at the top the total amounts and below it will be the details in a table format. The table format displays everything correctly, however the sum at the top omits when the table has duplicate values and so is incorrect.
  • Jun 30, 2022 8:49 AM UTC
just to throw ideas... maybe the sum of the top is a sum of distinct values? Then it will make sense that if finding a duplicate it will not add the amount....
Just my 0,02 €
  • Jun 30, 2022 1:35 PM UTC
Only used the numeric aggregator sum so seems very strange...Sum
  • Jun 30, 2022 3:24 PM UTC
Hmmmm
if you do the same using a single KPI for the aggregate, and a OLAP Table as the table details...
...what behaviour do you get?
Maybe it's the queries you are doing... just (again) throwing out ideas....
