Variable as Manually Defined Categories
I am trying to allow a bit of Text Mining in my analysis and do smth like
CASE WHEN table1.column1 LIKE <%=Variable1%> THEN table1.column1 ELSE NULL END
It works fine with a Variable defined with the help of the Variable Input component with to show thats a text piece. What I would like to do is to manually define some categories as a Variable and use them.
For example
https://aws1.discourse-cdn.com/business6/uploads/celonis4/original/1X/fef3cc0cb3c13c1042113fd0a5b20d725aa36e82.pngI would like to define Categories like Green, Red and Apples (for example in dropdown) so that i can just choose them without need to type them down everytime I need.
Any ideas?
Cheers,
Maria
joos.buijs
Level 6
Forum|alt.badge.img+2
What I usually do is to set the variable through a dropdown button. In the dropdown button component you can specify a formula to populate the dropdown list with values. Applying multiple selection is a bit trickier but this should work!
I could use the Formula like CASE IF table1.column1 LIKE Yellow then Yellow Else
But Id prefer a manually defined list of categories for the search.
Because if I use Yellow for the first case IF , I wont be able to look for Mangos
Greetings
Maria
Nevermind:) your r right:D it works also - I just enter manually the categories I need:D Thank you!
