Using OR in a Formula
  • Jun 11, 2020 9:29 AM UTC
  • 68 views
steven.bernd
Level 6
I need help with a formula.
COUNT (DISTINCT CASE WHEN EBAN. LOEKZ = X THEN EBAN. BANFN ELSE NULL END)
OR
COUNT (DISTINCT CASE WHEN EBAN. BSMNG! = 0 THEN EBAN. BANFN ELSE NULL END)
OR
COUNT (DISTINCT CASE WHEN MATCH_ACTIVITIES (NODE [Banf ist erledigt]) = 1 THEN EBAN. BANFN ELSE NULL END)
Here I would like to make a case distinction.
The formula doesnt work that way. There is an error.
I want to count my requisition
if either
  1. LOEKZ = X
  2. OR
  3. if 2. BSMNG is not equal to 0
  4. OR
  5. if the activity Banf ist erledigt is in the activity table.
It is only important that the BANF is counted only once.
That means that the BANF should have all 3 characteristics, so only 1 should be counted and not 3.
I hope I can get this through DISTINCT.
Thanks
Hi, have you tried to use COUNT(DISTINCT CASE WHEN EBAN. LOEKZ = X THEN EBAN. BANFN WHEN EBAN. BSMNG! = 0 THEN EBAN. BANFN WHEN MATCH_ACTIVITIES (NODE [Banf ist erledigt]) = 1 THEN EBAN.BANFN ELSE NULL END) Once a PR has one of the conditions, the case when statement will return 1 count, whether it has all 3 or just 1 condition. Best regards, Viana
