Multiple Data Engineers changing the same Transformation task code
I was editing the code in the Transformation task and at the same time, my colleague was also changing the same transformation task. Then, both the codes got reflected, which is not correct. Is there anyway through which we can restrict other person to access that code if someone else is working on it.
