MOVING_SUM using number of process variants
Hi, thank you for dropping by this topic. Im trying to use KPI Format as Start of MOVING_SUM. MOVING_SUM(COUNT_TABLE("_CEL_SD_ACTIVITIES_CASES"), KPI("Number of process variants") *-1,0) This KPI returns me an error: that start parameter should be an integer, which I firmly believe I am giving it integer. Using COUNT DISTINCT instead has not solved this situation btw. This should show the same result as the formula below. MOVING_SUM(COUNT_TABLE("_CEL_SD_ACTIVITIES_CASES"), -2,0) Best
Fidy: KPI(Number of process variants) *-1 Solved, when you use variant.
joos.buijs
Level 6
Forum|alt.badge.img+2
Hi Fidy, Youre using -1 in your answer. Is this correct or should it be a positive 1?
Hi joosbuijs,
-1 is actually correct usage, if you want to start accumulating the sum one number before, you may give -1 to the second variant.
I want to achieve in a line chart the gradual accumulation as the line goes to the right side, that is why I need to have SUM from negative numbers of starting point.
