Agentic Supply Chains and quantum percolated state
  • Oct 28, 2026 4:16 PM UTC
  • 5 views
Physicists have a precise answer to a question supply chain leaders are only starting to ask: what happens when you connect everything?
A recent preprint on quantum computer hardware shows a network that is small-world, and that above a critical coupling strength it percolates: isolated clusters suddenly become one giant connected component. Nothing gradual about it. It is a phase transition.
I find this a useful, if speculative, analogy for agentic supply chains. One agent handling delay alerts is a pilot. Ten agents each acting on their own slice are still islands. But once planning, procurement and logistics agents start reacting to each other's outputs, you may cross a threshold where a local decision becomes a network-wide event. Anyone who has watched the bullwhip effect knows how little it takes.
The practical lesson is not to avoid connecting agents. It is to measure coupling as you scale: who acts on whose output, with what delay, with which guardrails. Process intelligence gives you that map. Without it, you only discover the threshold after you have crossed it.
Where do you think your agent landscape sits today: islands, or already one connected system?
