What should I learn next?
  • Feb 26, 2025 11:11 PM UTC
  • 557 views
Iori Oshima
Level 4
Hi all,
I’m a beginner of Celonis. I belong to process office department, I’m in charge of CPM.
I’ve done the 5 learning contents “Celonis Process Management (CPM)”.
What should I learn next effectively?
It seems that there are the cource which is “Your journey”, so I think this is effective for me.
There are many courses available that can help you earn certifications, here are a few I recommend
Celonis Technical
  • Build Action Flows
  • Write PQL Queries
  • Get Data into Celonis
  • Build Analyses
  • Build Knowledge Models and Views
Solution Creation
  • Build Analyses
Value Realization
  • Create and Deliver Demos
  • Manage Implementation Projects
  • Deliver Business Value With Celonis
  • Manage Change & Scale Adoption
Value Assessment
  • Prove Celonis Value
  • Identify and Drive Opportunities
abhishek.chatu14
Celonis Technical
  • Write PQL Queries
  • Build Analyses
Solution Creation
  • Build Analyses
Value Realization
Value Assessment
Iori Oshima
Level 4
  • Level 4
  • Feb 27, 2025 7:39 AM UTC
Hi ​@abhishek.chatu14,
Thank you for the infomation!
I haven’t seen the certifications, so I’ll check them.
If you know that, is there the certifications for a beginner or associate? Actually I started to use CPM yesterday, so I’d like to get my basic skill improved.
