How to activate the process in Process Navigator?
  • Mar 10, 2025 7:48 AM UTC
  • 438 views
Iori Oshima
Level 4
Hi all,
I’d like to confirm the common release process.
I’m a article, and I’ve released the sub process but I couldn’t activate the process in Process Navigator.
I’ve alredy checked the Permitted set and there is no permission set.
What are common issues?
I can’t click in Process Navigator
Iori Oshima
Level 4
  • Level 4
  • Mar 10, 2025 11:13 PM UTC
Hi all,
After one day, I can activate the process in Process Navigator.
I didn’t change settings at all. Is it batch…?
caspar.jans
Forum|alt.badge.img+2
  • Celonaut
  • Aug 22, 2025 8:57 AM UTC
Hi, there is a daily batch job that, typically, runs during the European night hours, that publishes all of the released content from the Process Designer into the Process Navigator.
So, usually, if you release something on day 1, it ends up in the Navigator on day 2.
One common challenge is the following: if you have created a process hierarchy consisting out of mulitple levels of Main processes and you release a sub-process, you also need to make sure that all intermediate Main Processes levels in your process hierarchy are released as well, otherwise your process will not show up in the Process Navigator.
Regards, Caspar
