Dear all,trying to establish intelligent automation by and therefore looking for Integration options between Celonis and...Blue PrismAxon IvyPower PlatformSymbioGB-TecSMAP OneLUISCognigy AIAny ideas, connectors or Workarounds?
  • Nov 29, 2022 10:36 AM UTC
  • 435 views
Dear all, trying to establish intelligent automation by and therefore looking for Integration options between Celonis and... Blue Prism Axon Ivy Power Platform Symbio GB-Tec SMAP One LUIS Cognigy AI Any ideas, connectors or Workarounds?
abhishek.chatu14
Hi Stefan,
There are modules available for the same in Celonis Action Flow for the following
Blue Prism (https://docs.celonis.com/en/blue-prism--.html)
Microsoft Power Automate (https://docs.celonis.com/en/microsoft-power-automate.html)
For the rest you have HTTP(https://docs.celonis.com/en/http.html) and HTTP2(https://docs.celonis.com/en/http2.html) modules
These can help you make API calls to use:
  • GET - to retrieve information for an entry.
  • POST - to create a new entry.
  • PUT - to update/replace an existing entry.
  • PATCH - to make a partial entry update.
  • DELETE - to delete an entry.
Hope this helps !
  • Level 1
  • Apr 17, 2024 9:29 AM UTC
These Links are not working .. can you please update it
