Automation scope to save multiple records into knowledge model
  • Apr 30, 2026 10:50 AM UTC
  • 406 views
Pratheeksha
Level 5
Hello Everyone,
Working on a task where I need to save multiple components from a lot analyses into the knowledge model.
Is there any way we can fasten up things using pycelonis? It will help me save a lot records into the knowledge model without manually creating records in the knowledge model.
gagan1
  • Community MVP
  • May 1, 2026 9:05 AM UTC
Hi ​@Pratheeksha , Yeah PyCelonis is exactly what u want for this, will save u hours of manual data entry.
Assuming you are on a recent PyCelonis 2.x version (version 2.6+ added full native CRUD support for knowledge models[1]), you can just pull the components or formulas from your analysis and loop them directly into the KM.
The general logic looks something like this:
km = package.get_knowledge_models().find('Your KM Name')
analysis = package.get_analyses().find('Your Analysis Name')
# loop through your analysis components or saved formulas
for item in your_extracted_components:
km.add_record(
id="generate_a_unique_id_here",
display_name=item.name,
# map your PQL, attributes, etc. based on the analysis component
# u can also use km.create_kpi() if you are migrating KPIs
Pro-tip: Watch out for duplicate IDs when doing batch inserts. If the record or KPI ID already exists in the Knowledge Model, PyCelonis will usually throw an error. I usually check km.get_content().records first to see if it's already there, or just wrap the create step in a basic try/except block so one duplicate doesn't break the whole loop.
