Using Variable in KPI/Attribute Unit possible?
  • Mar 4, 2025 1:15 PM UTC
  • 464 views
Thomas Keim
Hello Community,
I would like to give my users the option to display an amount (e.g. freight) in any currency. To do this, I use the function CURRENCY_CONVERT_SAP and pass the target currency via a variable. This works perfectly.
My problem is the unit: Do you know of or is there a way to use my variable in the unit field so that the selected currency is automatically displayed as the unit?
Thank for help, Thomas
Β
Β
Best answer by Thomas Keim
I don't know whether I was blind or whether it has become possible with an update in the last few days: Now it is possible to use a variable in the Unit Field of a KPI in the Knowledge Model ✌🏻
It would be great if not only a variable but also an attribute were possible. For example, I have the fields NETWR and WAERK on the table VBAP.
  • NETWR e.g. 1000
  • WAERK e.g. EUR
Now I want to use the attribute VBAP.WERK in the unit field of NETWR with the result 1000 EUR.
I have made an Feature suggestion for this: CASEΒ 00350163
abhishek.chatu14
You can do this in the views, when displaying the unit pass the variable in the view instead of the KMΒ
Β
Β
Thomas Keim
  • Community MVP
  • Mar 5, 2025 2:30 PM UTC
OK, thank you 😊 not my preferred solution but better then nothing.
On further question:Β Would it then be possible to use a table attribute in the unit in the knowledge model?
E.g. I have stored the Currency in the field VTTK.WAERS … Can I use this field als Unit? If yes how?
Best, Thomas
abhishek.chatu14
I don't believe that is possibleΒ
Thomas Keim
  • Community MVP
  • Answer
  • Mar 19, 2025 2:58 PM UTC
  • NETWR e.g. 1000
  • WAERK e.g. EUR
