The Data Model Load experienced an issue with the Data Pipeline Orchestrator
  • Jan 23, 2025 2:15 PM UTC
  • 494 views
sunil.rai12
Level 1
Forum|alt.badge.img+11
Hi All,
I’ve following error message when trying to reload the OCPM data model:
The Data Model Load experienced an issue with the Data Pipeline Orchestrator. Celonis Support ID: 22950f46-9f10-46af-96de-887c2e2d81a5
Does anyone know what could be the issue here?
Thanks,
Sunil
ayushi.chakr11
Forum|alt.badge.img+2
Hi, Sunil. This generally happens when calendar settings are activated. I would suggest you to reload the data model after deactivating the calendar settings.
sunil.rai12
Level 1
  • Level 1
  • Jan 28, 2025 2:03 PM UTC
Thanks Ayushi, Tried after disabling calendar on the data model but getting the same error but when duplicated this perspective and reloaded copied data model, it’s reloading successfully and original data model still failing with same error.
