Generate Documentation for an OCPM Model
  • May 26, 2025 6:15 PM UTC
  • 544 views
pablo.siege
Level 2
Forum|alt.badge.img+10
Hello!!
Does anyone know if it is possible to generate a document with the complete documentation of an OCPM-Model (Objects, Events, Relationships (O2O & E2O) and Transformation Scripts)?
Thanks and best regards,
Pablo
  • Celonaut
  • Jun 9, 2025 10:19 AM UTC
Forum|alt.badge.img+28
Hi ​@pablo.siege,
This is possible, as described in this post:
Long story short: ask your Celonis representative for the PDF file where the link to this Repo is shared.
pablo.siege
Level 2
  • Level 2
  • Jun 12, 2025 12:10 AM UTC
Hi ​@Navya K
thanks for your reply!
I tried all the links you provided, but they appear to be internal Celonis sites and I don’t have access to any of them… is there another way I could get those documents?
Thanks!!
Pablo
pablo.siege
Level 2
  • Level 2
  • Jun 12, 2025 12:17 AM UTC
Hi ​@janpeter.van.d ,
Thanks for your reply!
I will do as suggested… Thanks!
Pablo
