What is the difference between action engine and action flows?
  • Aug 9, 2022 6:51 AM UTC
  • 179 views
Hi, I am in the middle of deciding on automation steps and want to understand difference between action engine and action flows.
Dear Siddhesh, Thank you for reaching out. The Action Engine is a rather old product that will get replaced by the task inbox at some point in time. The action flows run in the background, scanning the process for patterns. When a pattern occurs they either execute an action automatically or create a task in the task inbox. Many thanks and best regards, Tringa
  • Aug 12, 2022 6:38 AM UTC
Thanks Tringa..... another help if you can provide.... alike Action Engine, can attached Action Flow with Analyses to trigger the flow..... in a nut shell, do we have concept of Signal in Action Flow to act as a trigger point?
