Sending data from Action Flow to Action Flow without a Webhook
  • Aug 28, 2025 10:40 AM UTC
  • 474 views
marcelo.ferre11
Level 2
Forum|alt.badge.img+7
Hi Team,
I’m trying to send data from one Action Flow to another without using a webhook. Is that possible? Thanks in advance for your help!
shun.long.hong
Hi Marcelo,
nice to meet you! Can you describe your use case in more detail? :-) Why don’t you want to use webhooks?
jonas.hess
Level 7
Forum|alt.badge.img+3
  • Level 7
  • Sep 23, 2025 9:20 AM UTC
Hello, what you can do is to do a data pool write back in the first action Flow. And then build a trigger for the second Action Flow based on the write back table from the first Action Flow.
Otherwise if you dont want to write back into data pool, store it in Sharepoint and read it out with the second Action Flow
Kind regards Jonas
