Scripts for Infor-ERP system
  • Mar 17, 2023 11:06 AM UTC
  • 7 replies
  • 509 views
Dear Celopeers,
We already extracted the relevant tables from the customers system. Nevertheless, as the cutsomer is using Infor, we are lacking the expertise with this software.
Are there any scripts available which we can use in order to facilitate the next steps?
Thank you!
Kind regards
Raluca
indra.mehta11
Level 4
Forum|alt.badge.img+15
Hi Raluca Wurzingerq,
Which Process you have extracted the tables for? The next step is transformation after extracting the tables, where you have to write the sql scripts. If you are unable to write the scripts.
Celonis Provides Verities of Process connectors which are available in Market Place. You can use these connectors.
Regards
Indra
Forum|alt.badge.img+28
Hi ​@raluca.wurzi,
I guess this answer is too late, but it’s more for future Community visitors.
Currently Celonis do not provide any process connectors for the Infor ERP systems, both LN and M3.
We as Marcadus have made this as one of our expertises, and have Object Centric connectors available for both LN and M3 for the most common processes (Procurement, Order Management, AR, AP, Inventory Management).
Using these mappings, you can deploy Object Centric Apps from the Marketplace on top of the Infor connection.
We’re happy to help you out in this technical part of your project.
Feel free to reach out by sending me a DM, visit our company page in the Marketplace (https://marketplace.celonis.com/store/ui/partners/marcadus), or visit our website (www.marcadus.com).
asdfg
Level 6
  • Sep 10, 2025 12:25 PM UTC
​@janpeter.van.d how is your connector techinically connecting to Infor LN? Does it support cloud or only on-prem systems?
​@asdfg we can extract data both from the On-premise and Cloud version of Infor LN. The transformations to populate the Celonis objects with Infor data, work on both type of sources.
Let me know if we can assist with any further steps.
asdfg
Level 6
  • Sep 11, 2025 4:42 AM UTC
I know you can extract data from cloud, but can the Celonis connector you’ve created. :) I just want to get a better understanding what’s the technology behind that part in your solution.
​@asdfg I’ll send you a Direct Message!
asdfg
Level 6
  • Sep 11, 2025 8:19 AM UTC
Cheers :)
