Problem running Nested Skills, does anyone have experience in triggering skills from another skill?
  • Feb 23, 2023 4:19 PM UTC
  • 210 views
I'm trying to kick of a manual sensor skill by using the execute process automation skill. Running this skill than triggers the manual input that is required in the subskill. Has anyone gotten to make such a link working? I'm struggling with not knowing where the issue exactly lies, since the error message is extremely vague.Example of occurred error
Best answer by rio.cinco12
Hi, you can follow the link below to do this. Create a skills and save it as an action where you can then use in the flow.
https://docs.celonis.com/en/save-skills-as-actions.html
Hope that helps,
Rio
Forum|alt.badge.img+14
  • Level 8
  • Answer
  • Feb 24, 2023 8:08 AM UTC
Hope that helps,
Rio
  • Feb 24, 2023 8:28 AM UTC
Thanks Rio,
It works when saved to an action. Weird that you can not use it as a skill itself, according to the same documentation (point 2 in the link you provided), that should also be possible. I guess Celonis could update the documentation on this :)
