Is it possible to use a dropdown menu when using Actions to trigger an Action Flow?
  • Nov 13, 2023 10:31 AM UTC
  • 106 views
Hi all,
With Automation Skills, it is possible to update an Augmented Attribute with a dropdown list using Actions. The action button triggers an Automation Skill which updates the Augmented Attribute. I would like to migrate this action from Automation Skills to Action Flows, but I'm unsure about how to include dropdown values in an Action Flow.
Anyone that knows how to do this?
Thanks,
Teun
  • Level 0
  • Nov 21, 2023 11:42 PM UTC
Dear Teun,
Thank you for reaching out to us.
To be able to assist you further, we would suggest sending an email to servicedesk@celonis.com with a detailed description.
We will gladly try to help you.
We are always here to help and look forward to hearing from you.
Thanks and regards,
