How to make automation skill input optional?
  • Aug 1, 2023 3:41 PM UTC
  • 129 views
Does anyone know how to make an input for an automation skill optional?
The option is greyed out for me. I would like to be able to trigger a skill using an action without having to fill fields if they are empty.
Thanks!
Teun
Hello Teun, could you please check the article below? Skill Configure Execution Page - Input Optional https://www.celopeers.com/s/article/Skill-Configure-Execution-Page-Input-Optional
  • Aug 4, 2023 11:22 AM UTC
Hi @keiko.koyam11,
Thank you for your response.
I did see this article. If I understand correctly, by definition, input from a sensor cannot be optional, correct?
If that's the case, I wonder whether there's a way around.
Do you know how I can achieve that a skill gets triggered without manual input from a user, even if there are NULL values for some of the required fields?
Thanks!
Teun
Hi Teun Gilissen,
Thank you for your understanding.
To trigger a skill without manual input from a user, you can just set a default value for the fields. Then toggle on "Request manual input from user" and then "Manual input" on the fields, which should allow end users to enter a value. You can set their default values, which can be changed or left untouched.
Please let us know if you have any questions regarding the above.
Thank you!
Celonis Customer Support
