How good is to use Power BI with data from Celonis powered knowledge models?
  • Feb 20, 2023 12:59 PM UTC
  • 113 views
My organization is currently using Power BI and some reports are on Power BI and some are on Celonis as well (I know it is not a good idea to use Celonis for only simple reporting purpose). So I am planning to propose …to make PowerBI the face for reporting requirements and Celonis for Use case building (even use case dashboards can also be moved to PowerBI)
Before I propose, I wanted to get some confirmation/clarification:
1)     Will the data on PowerBI be real time? or PowerBi will again need scheduling data pull?
2)    Will PowerBI hold data or it will remain on Celonis cloud only and used by PowerBI directly?
3)    If Data is on Celonis cloud, what will be the impact on performance (since data will be queried from Celonis)?
Dear Dinesh, Kindly see below some of our help articles regarding Power BI https://docs.celonis.com/en/microsoft-power-bi.html https://docs.celonis.com/en/ems-connector-for-power-bi.html https://docs.celonis.com/en/connect-to-celonis-ems-using-power-bi-desktop.html https://docs.celonis.com/en/celonis-apps-for-power-bi.html For more information, we would suggest sending an email to servicedesk@celonis.com and we will do our best to provide you with more details as needed. Many thanks for your patience and understanding. Best regards, Valmira Abdiu
