Array aggregator can't read two bundles from Get Row module
  • Feb 28, 2025 10:17 AM UTC
  • 332 views
Andreas Siebler
Level 2
Hi everyone,
I have a question regarding Action Flow.
I use a Get Rows module and get two bundles as a Output.
Once I wanna use the two bundles in a further module within the Action Flow, I cannot select any of my columns I defined in my Get Rows module. The only columns I can select is “Total number of bundles”, “Bundle order position”, “undefined”.
I haven’t found any documentation or similar issues in the community. If anybody has an idea how I can select my defined columns highly welcome to respond.
Thank you
Andreas
Andreas Siebler
Level 2
Solved.
You have to trigger the Get Row module once manually, so that the array aggregator can read the columns.
BR
