Anyone now if there is a way to delete files from sharepoint using action flow?
  • Nov 14, 2024 12:40 PM UTC
  • 217 views
carmem.caval
Level 4
I'm using a SharePoint connector and the Microsoft 365 module to read data from XLSX files. These files are constantly updated, and I needed a way to get rid of them after a certain time. I know that Microsoft 365 has a function to delete a table, but it deletes a sheet, not the whole file. The SharePoint module has a "Delete an Item" action, but it doesn't seem to bring the correct files. Is there a way to do this? If not, is there a way to move files from one path to another inside SharePoint, still using only Action Flow?
shun.long.hong
Hi Carmen,
can you please specify what you mean with “… it doesn't seem to bring the correct files”? I assume that you already granted the necessary read and write permissions?
