Using Pu functions instead of Aggregates to be able to Filter KPIs
  • Apr 9, 2025 3:10 PM UTC
  • 311 views
NHARNIS
Level 2
Hello Celopeers,
im new to Celonis and have created a view. There i use a Kpi which drops a lot of zero values. When trying to filter them out i always get the error that aggregated functions can not be used in combination with the FILTER function, and that i should try PU functions.
The KPI i'm using is this:
SUM(
 CASE
  WHEN round_day("o_custom_KnotenpunktAuftrag"."AusgangForecast") = round_day("o_custom_KnotenpunktFuellstand"."Date")
  THEN 1
  ELSE 0
or alternetively this :
COUNT(DISTINCT
case when round_day("o_custom_KnotenpunktAuftrag"."AusgangForecast")
 =round_day("o_custom_KnotenpunktFuellstand"."Date")
 then
  "o_custom_KnotenpunktFuellstand"."KnotenpunktAuftrag_ID"
end)
is simply want to calculate for each KnotenpunktFuellstand.Date, how many Order.IDs i have where the filter condition is met.
So i can have a table where im using the date plus KPI to see, how many outgoing orders i can except for each date.
How can i have a row-count, based on a condition formulated as a PU function so i can filter the KPI?
PU_COUNT ("o_custom_KnotenpunktAuftrag", "o_custom_KnotenpunktFuellstand"."ID")
Trying something like this just give me back for each ID how often it finds each ID in o_custom_KnotenpunktAuftrag.
Niklas
Best answer by atharva.patil12
Hi Niklas, using a PU_COUNT_DISTINCT function here with a domain table may work here. I was thinking something like PU_COUNT_DISTINCT (
    DOMAIN_TABLE(ROUND_DAY("o_custom_KnotenpunktFuellstand"."Date")),
    "o_custom_KnotenpunktFuellstand"."KnotenpunktAuftrag_ID",
    FILTER round_day("o_custom_KnotenpunktAuftrag"."AusgangForecast") = round_day("o_custom_KnotenpunktFuellstand"."Date")
Id recommend viewing the documentation for domain tables if you’re new to celonis, they can be quite handy!
NHARNIS
Level 2
  • Level 2
  • Apr 15, 2025 1:27 PM UTC
@atharva.patil12 Thank you very much!
The Domain Table was the way to go. I still had to inculde the other columns of the table i displayed in the Domain table, so that it calculates on each relation.
Still im a bit confused how the domain table in the PU context works..
how can   "o_custom_KnotenpunktFuellstand"."KnotenpunktAuftrag_ID" be found in the domain table, even if i don’t include it. I tried incluing it as well but then i just got 1 on every relation.
