Using DAYS_BETWEEN in a Case When statement
  • Feb 13, 2020 3:34 PM UTC
  • 125 views
Hi all, I want to set a value based on different conditions. If I do Median( case when Eventlog_casestates_GDP_csv.CASE_STATE = running then case when (<%= Durchlaufzeit_Median %> > DAYS_BETWEEN(PU_FIRST(Eventlog_cases_GDP_csv, Eventlog_activities_GDP_csv.TIMESTAMP),TODAY())) then <%= Durchlaufzeit_Median %> else NULL end else CALC_THROUGHPUT(ALL_OCCURRENCE[Process Start] TO ALL_OCCURRENCE[Process End], REMAP_TIMESTAMPS(Eventlog_activities_GDP_csv.TIMESTAMP, DAYS)) end) but actually I want to set the days between as well. So if I do Median( case when Eventlog_casestates_GDP_csv.CASE_STATE = running then case when (<%= Durchlaufzeit_Median %> > DAYS_BETWEEN(PU_FIRST(Eventlog_cases_GDP_csv, Eventlog_activities_GDP_csv.TIMESTAMP),TODAY())) then <%= Durchlaufzeit_Median %> else DAYS_BETWEEN(PU_FIRST(Eventlog_cases_GDP_csv, Eventlog_activities_GDP_csv.TIMESTAMP),TODAY()) end else CALC_THROUGHPUT(ALL_OCCURRENCE[Process Start] TO ALL_OCCURRENCE[Process End], REMAP_TIMESTAMPS(Eventlog_activities_GDP_csv.TIMESTAMP, DAYS)) end) this error occurs: Operator requirements are not met. Operator CASE is not compatible with cases of type: INT and FLOAT. How can I solve this?
Hi, in a CASE WHEN, you always need to return values of the same data type. DAYS_BETWEEN returns a FLOAT, while CALC_THROUGHPUT returns an INT. As the first query works, I assume that the Durchlaufszeit_Median variable is an INT as well? So you have two options: You can either apply ROUND or FLOOR or CEIL to the DAYS_BETWEEN to make it an INT, or you can multiply the CALC_THROUGHPUT and the Durchlaufszeit_Median variable with 1.0, which basically casts the INT to a FLOAT. Cheers David
  • Level 3
  • Feb 14, 2020 8:24 AM UTC
Hallo David, thank you so much! Using round works perfectly. Kr, Mara
