Use Variable as Column Header
  • February 20, 2020
  • 68 views
Dears, Is it possible to use a variable to as a column header? In the example below , Variable Visualization_KRI_Main_title , contains the name of the selected KPI (i.e. Ratio of XXX) , we want to use this variable as a header. screen1076720 64.7 KB Can you please advise? Thanks!
Hi @cristian.garofalo, thanks for reaching out to us! I have replicated the issue and for me it works fine. image1109827 42.8 KB To further investigate why it didnt work for you, let me raise some question:
  • Did you define a variable for the title as well?
  • Did you consider that calling a variable is case sensitive?
Best regards, Justin
