Throughput time based on first occurrence and ignore multiple/duplicate same activities
  • Apr 22, 2025 6:39 AM UTC
  • 112 views
markus.golka
Level 1
Hello all,
I would like to calculate the througput time from activity to next different activity.
The Challenge:
My process has activities which occurs multiple times with the same name directly one after the other. This is no data issue, the process is designed that way.
In case the activity with the same name occurs later in the process again, this should be count as well and not ignored.
What is the time to the next activity, which does not have the same name?
Process example:
Avtivity       Timestamp
A    01:00 pm
B    01:30 pm
B    01:45 pm
B    02:15 pm
C    03:00 pm
C    03:20 pm
D    03:45 pm
E    04:00 pm
E    04:50 pm
A    05:00 pm
Expected Result:
Avtivity       Duration
A                30min
B                1h 30min
C                45min
D                15min
E                10min
Does anybody know a solution or a community post, which can help me?
