Thoughputs of each clients are higher than average throughput
  • Mar 13, 2020 1:17 PM UTC
  • 94 views
Dear community, I would like to create an OLAP table to calculate throughputs from Process Start to"Process End" of each client. My data model is single eventlog, Case_table, which consists of Process group, Activity, Time stamp, and Client. Every records of case table have client name( client1 - 4) in client column. I tried to make OLAP table like this.
  • DIMENSIONS (1)Cient: CASE WHEN Case_table.Client = Client1 THEN Client-01 WHEN Case_table.Client = Client2 THEN Client-02 WHEN Case_table.Client = Client3 THEN Client-03 WHEN Case_table.Client = Client4 THEN Client-04 ELSE END
  • KPIS (1)Throughput: AVG(CALC_THROUGHPUT(CASE_START TO CASE_END, REMAP_TIMESTAMPS(Case_table.Time stamp, Seconds)))
It looked working, but the result was wired. The throughput of each client is higher than average throughput. When I delete dimension, OLAP table shows average troughput lower than each clients throughput. Does anyone know how to solve this problem? Thank you for your support. Sugano
  • Mar 13, 2020 3:58 PM UTC
Dear @Sugano, try this instead of CALC_THROUGHPUT: AVG( SECOUNDS_BETWEEN( PU_FIRST("MAPPING_TABLE", "ACTIVITIES"."EVENTTIME", "ACTIVITIES"."ACTIVITY" = 'CASE_START' ), PU_LAST("MAPPING_TABLE", "ACTIVITIES"."EVENTTIME", "ACTIVITIES"."ACTIVITY" = 'CASE_END' ) ) ) Best regards, Chanyut
  • Level 2
  • Mar 14, 2020 3:15 PM UTC
Dear Chanyut Thank you for your support. I tried a following statement as you mentioned above. AVG( SECONDS_BETWEEN( PU_FIRST(MAPPING_TABLE, ACTIVITIES.Time stamp), PU_LAST(MAPPING_TABLE, ACTIVITIES.Time stamp) ) ) This statement worked same as CALC_THROUGHPUT. I assume that the dimensions has a problem.
  • Mar 17, 2020 3:02 PM UTC
Hi Sugano In some cases you might have activities between your process path which its thoughput times are lower than avg throughput times. This might lead to an outlier issue. (Use Case Explorer to identify if such cases existed) Possible Solutions:
  • Use MEDIAN() instead of AVG() to solves statistical outliers issue.
  • Exclude undue activities by using component filter for your OLAP
BR, Chan
