The aggregation function MAX cannot be used together with a dimension function input. Please check that there are no aggregations and dimensions used together as function inputs
  • Feb 28, 2025 1:25 AM UTC
  • 420 views
PhuongBHN
Level 3
I would like to create a KPI to count the cases of the previous month do a dropdown but I keep getting a message that "The aggregation function MAX cannot be used together with a dimension function input. Please check that there are no aggregations and dimensions used together as function inputs.” .Have you got idea how to do it?
MY pql:
COUNT( DISTINCT CASE WHEN ROUND_MONTH("EKKO"."AEDAT") = MAX(ROUND_MONTH("EKKO"."AEDAT"))
THEN "EKKO"."MANDT"
abhishek.chatu14
You cannot use a MAX function inside a COUNT, aggregation will not work with dimension function.
Try this instead
COUNT( DISTINCT CASE WHEN ROUND_MONTH("EKKO"."AEDAT") = PU_MAX(DOMAIN_TABLE("EKKO"."EBELN"),ROUND_MONTH("EKKO"."AEDAT"))
THEN "EKKO"."MANDT"
PhuongBHN
Level 3
  • Level 3
  • Mar 3, 2025 6:43 AM UTC
Try this instead
THEN "EKKO"."MANDT"
Thanks for your help,
This PQL below resolved my case:
COUNT(DISTINCT
CASE WHEN ROUND_MONTH("EKKO"."AEDAT") = PU_MAX(CONSTANT(), FILTER_TO_NULL (ROUND_MONTH("EKKO"."AEDAT"))
THEN "EKKO"."MANDT" END )
