Text replacement in Studio Action Flow
  • Jul 6, 2023 12:44 PM UTC
  • 72 views
Is there a way to replace text in Action Flows?
We need to remove newline characters from a string input.
Currently this is being done in Studio Skills, but it would be better for our workflow if this was possible within an Action Flow. Wondering if anyone has done this.
Regards,
Ravi
  • Level 6
  • Jul 10, 2023 11:19 AM UTC
Hi @ravi.nair12 ,
Action Flows does provide some string manipulation functions. PFB screenshot for your reference.
imageHope this helps!
Shravya B
