Runtime variable plain text not visible in analysis
  • Jan 20, 2025 5:56 AM UTC
  • 118 views
raman.silot11
Level 3
While creating plain text runtime variable, it is not visible in the analysis filters.
Even after publishing the package it is not appearing.
Is there any recent changes done to runtime variables in Celonis ?
Thank You
Usually the runtime variables used to be mentioned on the left panel
abhishek.chatu14
I don't believe run time variable was ever available on Analysis. You can check the same while creating a view
raman.silot11
Level 3
ohh… must be my dilemma :)
but still can we use these variables somehow in analysis ?
