Retrieving the YAML code for knowledge models using Pycelonis in MLWB
  • Jun 17, 2026 2:45 PM UTC
  • 574 views
Pratheeksha
Level 5
Hey Everyone,
I can connect to a knowledge model and pull the data within into the MLWB using pycelonis.
But can we retrieve the knowledge model YAML code and store it in MLWB?
Please help me with this concern if there is a way.
Harshit Jain
Hi Pratheeksha,
Yes we can retrieve the YAML Code in MLWB
Use this code:
# ── Retrieve a Knowledge Model's YAML and save it in MLWB ──────────────
celonis = get_celonis()          # uses MLWB env vars automatically
PACKAGE_KEY = "<your_package_key>"   # the Studio package holding the KM
# 1. List the nodes (assets) in the package via the package-manager API
resp = celonis.client.get(
    f"{celonis.url}/package-manager/api/packages/{PACKAGE_KEY}/nodes"
# 2. Inspect the structure once so you know the field names
print(resp)
# 3. Pull the KM node's serialized YAML body and write it to disk
for node in resp:
    if node.get("assetType") == "KNOWLEDGE_MODEL":   # adjust if type differs
        yaml_text = node.get("serializedContent", "")
        fname = f"{node.get('key', 'knowledge_model')}.yml"
        with open(fname, "w") as f:
            f.write(yaml_text)
        print(f"Saved: {fname}")
Let me know if you need more support.
Regards
Harshit Jain​​​​​​​
