Reconfiguring case id , after we have created dashboard , how to do that ?
  • Apr 26, 2023 8:19 AM UTC
  • 124 views
Dear experts , i wish to verify some metrics using different case id after i created my analysis on first case id. Can you advise how can i reconfigure the case id ?
Forum|alt.badge.img+28
Hi Shaif,
This can be done easily in the Data Model. Go to the options of your activity table and select 'Edit Activity Columns' (see screenshot below). If you have assigned a case table, be sure to also remove/reconfigure this one according to your new Case ID settings.
Reconfigure Activity Table Screenshot
  • Apr 26, 2023 8:41 AM UTC
Thank you Jan , much appreciated
  • Apr 26, 2023 12:53 PM UTC
Also, good practice: use CASE_TABLE and ACTIVITY_TABLE as much as possible.
That way if you change the table name, or the column names, you reduce the need to review the PQL
https://docs.celonis.com/en/process-reference.html
You're welcome!
