Processing high volume data from PLC’s
  • Feb 2, 2021 11:13 AM UTC
  • 57 views
Would it be possible for Celonis to process real time high volume data from PLCs. Most use cases I see have to do with administrative processes. How about PLC data processing? Anybody with experience on this topic?
Hi @rob.buijt,
could you please elaborate a little bit on what you are looking for in detail? It is hard to find an answer if the questions is not clearly stated. Happy to discuss the topic further as soon as we have further information!
  • Level 2
  • Nov 22, 2021 2:19 PM UTC
Within van Oord we've dredging vessels which produce huge volumes of sensor data related to the dredging process on that vessel (TB's). The data is produced by PLC's. Would it be possible for Celonis to take this type of data in?
You could check out our streaming functionalities using Kafka as a connector. You can find further information here: https://www.celonis.com/ems/platform/real-time-data-ingestion/kafka-connector/
If you require further information on this, you could reach out to your Customer Value Manager to discuss that topic further!
  • Level 0
  • Nov 22, 2021 4:41 PM UTC
In case you are not able to find the relevant information, you can also open a ServiceDesk ticket explaining your problem. They will route it to the correct people.
