Process flow analysis
  • Mar 31, 2025 10:42 AM UTC
  • 378 views
Bharath
Level 4
PROCESS FLOW
Need some assistance,
I have a CaseID, Activity and Timestamp. I need to get all the cases where the activity flow is A to B to C.
(NOTE: the activities don't have to be directly followed by)
I cannot use MATCH_PROCESS_REGEX or any other commads. I need to used CASE WHEN, AND, ACTIVITY_LEAD etc... to solve this.
Please help me out.
My approach
CASE WHEN "tab"."Activity" = 'A'
AND ACTIVITY_LEAD(CASE WHEN "tab"."Activity" = 'A' THEN "tab"."Activity" END) = 'B'
AND ACTIVITY_LEAD(CASE WHEN "tab"."Activity" = 'B' THEN "tab"."Activity" END) = 'C'
THEN CaseID
abhishek.chatu14
Try something like this
CASE WHEN PROCESS EQUALS 'Activity 1' TO ANY TO 'Activity 2' TO ANY TO 'Activity 3' END THEN CaseID
I am actually not sure if this works with CASE WHEN
Bharath
Level 4
  • Level 4
  • Apr 1, 2025 10:20 AM UTC
Yes i did not try like this, i used this PROCESS EQUALS in a PU_COUNT function. but the thing is i should solve this using only ACTIVITY_LEAD concept. Can you help out with it?
abhishek.chatu14
In your case the activities don't have to be directly followed by each, try going through the following will help you get a solution
Ping Pong Cases
Bharath
Level 4
  • Level 4
  • Apr 2, 2025 8:48 AM UTC
Got it. Thank you for the insights.
