PNG Download of Process Flow Truncated
  • Aug 25, 2020 12:20 PM UTC
  • 99 views
Hello Team, Im downloading the Process Flow from the Process Explorer as a PNG Output. Unfortunately the left most part of my PNG output is getting truncated. Are there any settings whereing I can specify the width, so that the PNG download is not getting truncated. Attached is the leftmost part of my process flow which shows the TP time as 81 Minutes. But in the PNG download, it shows only the Connection line with only minutes without 81. Kindly advice. Warm Regards, Jayanta Borkakoti
  • Level 0
  • Nov 22, 2021 8:42 PM UTC
@1460043623 There are currently no settings to adjust this. I would recommend to open a ServiceDesk ticket to see if they can provide you with a workaround potentially
Kevin
gabriel.okaba11
Hello Jayanta,
i've just tested the feature and seems that it has been fixed. I`m getting the full PE as png instead of a cropped one. Couldyou try again?
Gabriel
