Pattern for detecting numbers in PQL
  • Oct 30, 2025 1:03 PM UTC
  • 317 views
fabian.wende
Level 6
Hello Community,
maybe I am just blind and didn’t find it yet in the documentation, but could it be that there isn’t any possibility to determine if there is a number in a specific pattern?
I’ve got a column “unit” which got values like ‘A123’ and ‘AB12’ - I need to filter out every unit which got no number on second position.
Like in regex, I can do: ^(.)\d to get if the second character of my string is a number.
SQL Patindex also can do very basic capturing groups like %[0-9]%  - which will give me 2 if the first number is on second place.
At the moment I am doing this with this PQL:
TO_INT(
SUBSTRING("TA_MR_PKC_EVENT"."BEARBEITENDE_ORGA",1,1)
Which results in NULL if the second position isn’t a number - I can work with that, I am totally fine about it -  but I am a little bit curious if there is an more elegant way in doing this.
Fabian
Forum|alt.badge.img+28
COLUMN_TYPE should exactly do this: https://docs.celonis.com/en/column_type.html
fabian.wende
Level 6
  • Level 6
  • Oct 31, 2025 8:59 AM UTC
Hi Jan Peter,
thank you very much for your answer! But if I understand COLUMN_TYPE correctly, it only gives me the type of one column of the datamodell - which is always STRING in my use case.
I only want to check the Type of one segment of the String - here specifically the second position.
Hmm, good point, I was a bit too quick here. I expected that it used character recognition, but it seems indeed that it’s using the database’s datatype.
In that case, I think you’ve found quite a good and clean workaround doing this!
