Passing Identifier to Get Task with Smart Sensor
  • Aug 3, 2021 7:56 AM UTC
  • 72 views
I use a manual sensor to reopen tasks in Views. Right now I try to create a solution that would reopen tasks based on the Smart Sensor.
In order to do so, I duplicated the Manual skill and changed the trigger from Manual to Smart sensor choosing the same Knowledge Model and Record Identifier and applying PQL filters. The skill preview shows a number of tasks as I would expect.
The issue I have is that at Get Task stage there is no identifier passed and the skill cannot get reopen even though I use the same identifier as I use with skill created as Manual Sensor.
Forum|alt.badge.img+27
Hi Mateusz,
We are experimenting with the action flows and found out that you can pass variables in the url of the webhook by adding a question mark after the webhook url, and then state your identifiers. Not sure if this is also applicable to your case, but maybe it is worth a try. Our URL looks something like this, where the parts between de curly brackets are placeholders.
https://<team>.eu-1.celonis.cloud/ems-automation/public/api/root/<id>/hook/<id>?orderid=${Purchase Order}&lineid=${Purchase Order Line}
