Package creation flow supports object-centric process mining (2023-05-31)
  • May 31, 2023 12:09 PM UTC
  • 71 views
You can now include perspectives in Studio Packages for object-centric process mining. Perspectives are views on the object-centric data model including a subset of the object types and event types that is relevant to a process, or to another grouping that you want to analyze. See Perspectives for more information about them.
You include perspectives in a Package using Data Model variables. A package can't contain a mix of case-centric Data Models and object-centric perspectives. They all need to be the same type as the one you use in the first Data Model variable that you add to the Package - so either all perspectives, or all case-centric Data Models. To swap a package between case-centric and object-centric models, you'll need to take all the variables of the previous model type out before adding the new type.
