Operator requirements are not met. Operator ‘ADD_DAYS’ is not compatible with inputs of type DATE and FLOAT
  • Mar 1, 2021 5:29 AM UTC
  • 190 views
ADD_DAYS(KPI(BLINE_DATE),KPI(CATEGORY_VENDOR_TERMS_DAYS)) where KPI(CATEGORY_VENDOR_TERMS_DAYS) = GREATEST(KPI(INVOICE_TERMS_DAYS),KPI(REG_VENDOR_TERM_DAYS)). The output of above KPIs is days only in INT value. Not sure why this error is showing up.
  • Level 0
  • Nov 9, 2021 12:57 PM UTC
Hi Ankita,
it seems that KPI(CATEGORY_VENDOR_TERMS_DAYS) is somehow in FLOAT. Can you try to put TO_INT(KPI(CATEGORY_VENDOR_TERMS_DAYS)) and see if this works?
  • Jan 5, 2023 7:41 PM UTC
Hi, I am trying to do the exact same thing. I tried the TO_INT function and I am being given the error that TO_INT is not compatible with FLOAT. I thought the whole point of the TO_INT function was to convert float to integer. float to int
