on click functionality for a KPI
  • Oct 6, 2022 8:10 AM UTC
  • 92 views
is it possible to have an on-click functionality for a KPI ?, like I am not talking about button, what I mean is whenever we click on a KPI we redirect to another module or webpage
  • Oct 6, 2022 9:39 AM UTC
I think not, the only thing you can try to use is IFrame component in Business Views that just show you the PDF or specific site - then it's up to site if it will redirect you or not. I think besides that there's no easy way to do that.
Mateusz Dudek
  • Oct 6, 2022 11:08 AM UTC
I agree with Mateusz that is not possible.
I tried a "hack" putting a url <a href= ...> tag in the KPI name, but it doesn't work
Only other possibility would be to configure the user interaction to store a url in a variable, and then use a button loaded with that variable...
  • Oct 11, 2022 7:58 AM UTC
Ok Thank You
