Need HELP: KPI for Touchless or Manual Intervention or Unknown
  • Jun 21, 2019 9:17 AM UTC
  • 169 views
Hello
I am trying to create a KPI called PO Touch Indicator that will allow me to have a Value of touchless, manual intervention, or unknown based on the activites and User Type per PO.
When AT LEAST one UserType = - then unknown
When ALL UserType = B then Touchless
When AT LEAST one UserType = A and rest are B or all are A then Manual intervention
Ex 1:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: A // KPI "PO Touch Indicator: unknown
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: - // KPI "PO Touch Indicator: unknown
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: unknown
Ex 2:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: B // KPI "PO Touch Indicator: touchless
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: B // KPI "PO Touch Indicator: touchless
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: touchless
Ex 3:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: A // KPI "PO Touch Indicator: manual intervention
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: A // KPI "PO Touch Indicator: manual intervention
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: 'manual intervention
Hello Neel, This is best solved by a Case When Statement. I think the shortest way would be to Count the Distinct User Types on Case Level. If its 1 User Type and that User is B then its touchless, if the Count of - Users is greater than 0 its unknown and all the rest would be manual intervention. Best regards, Benedict
  • Level 2
  • Jun 25, 2019 3:34 PM UTC
Hi Bene Thank you for your advise can you please give me an example this CASE WHEN statement ? Im not too sure how to write this formula thank you !
Hey Neel, In order to calculate something from the activity table on case level, one has to use PU_Functions. Please see our PQL-Reference for more Information on them. Something like this should work: CASE WHEN PU_COUNT_DISTINCT(YourCaseTable, YourActivityTable.USERTYPE) = 1 AND PU_LAST(YourCaseTable, YourActivityTable.USERTYPE) = B THEN Touchless WHEN PU_COUNT(YourCaseTable, YourActivityTable.USERTYPE, YourActivityTable.USERTYPE = -) > 0 THEN Unknown ELSE Manual Intervention END Best Regards, Bene
