Need Help Fixing PQL script to look for a variable direct after a wildcard search using the LIKE function
  • Jun 13, 2025 8:05 PM UTC
  • 200 views
christine.gentr
Level 2
I need help fixing my PQL script
CASE
  WHEN "SHOPPING_DETAILS_DESC" LIKE '%CRIT% 1%' THEN 'Criteria 1'
  WHEN "SHOPPING_DETAILS_DESC" LIKE '%CRIT% 3%' THEN 'Criteria 3'
  WHEN "SHOPPING_DETAILS_DESC" LIKE '%CRIT% 5%' THEN 'Criteria 5'
  ELSE NULL
I am trying task search in a text field (Shopping_Details_Desc) for cases where ‘%CRIT%’ is identified. I would then like the code to assign a Criteria when the number ‘1’, ‘3’ or ‘5’ follow directly after the we wildcard search. I am pulling errors because there are other numbers in the text description and the code is incorrectly assigning them because it is find any any ‘1’ (as an example) that comes after ‘CRIT’ and then calling it a ‘Criteria 1’, even when it is a Criteria 3.
My issue is that sometimes our operators are miss writing the text so we are trying to capture either CRIT or CRITERIA, or anything in between - which is why I want a wild card.
I was able to write a statement in DAX to be able to look for a number assigned directly after the CRIT, but I cannot seem to figure out how to do this in PQL.
Criteria Flag =
VAR CritType = [Shopping_Details_Crit_Type]
RETURN
IF(
FIND("1", CritType, 1, 0) > 0,
"Criteria 1",
IF (
FIND("3", CritType, 1, 0) > 0,
"Criteria 3",
IF (
FIND("5", CritType, 1, 0) > 0,
"Criteria 5",
BLANK()
It was really lovely meeting many of you during the PI days last week and really appreciate anyone who can support resolving this!
  • Celonaut
  • Jun 16, 2025 11:53 AM UTC
Hello Christine, can you try this script and let me know if it works?
CASE WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*1(?:\D|$).*') THEN 'Criteria 1' WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*3(?:\D|$).*') THEN 'Criteria 3' WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*5(?:\D|$).*') THEN 'Criteria 5' ELSE NULL END.
christine.gentr
Level 2
Hi Navya,
Thank you for sharing this potential solution. I tried this script and am getting a formula error saying that ‘\s’ is an invalid character. I tried to flip the \ to / in case that was a mistype and got an error at line 26.
Any ideas on how to fix this?
Thanks for all your help!
  • Celonaut
  • Jun 24, 2025 11:45 AM UTC
Hey! ,
I’m so sorry that you have to face this error, can you try the following script and let me know?CASE WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*1([^0-9]|$).*') THEN 'Criteria 1' WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*3([^0-9]|$).*') THEN 'Criteria 3' WHEN MATCH_REGEX("SHOPPING_DETAILS_DESC", '.*CRIT(?:ERIA)?\s*5([^0-9]|$).*') THEN 'Criteria 5' ELSE NULL END
christine.gentr
Level 2
Thank you for working to help resolve this, I am learning PQL from scratch so this is so helpful to figure out how to write a complex wild card function. I am still getting the same error with the ‘\s’ escape character. I have a case centric data model, idk if this is causing the issue?
Thank you again for all your help!
BR
a
