Is there a way to reference Knowledge Model Variables in Studio Dashboards?
  • Aug 25, 2021 3:23 PM UTC
  • 146 views
Good afternoon,
Just wondering if there was a way where I could use the variables we've set up in the Knowledge Model, inside the dashboards, for page filters, etc.
Thank you!
  • Sep 24, 2021 6:37 AM UTC
Hi @vasco.caron11
Global filters in the Knowledge Model are applied as filters in Studio Analysis as well. Those filters behave the same way as Load Script in the Analysis. If Load Script already exists for an Analysis, then the global filter along with the Load Script filter are collaboratively applied.
You can store and maintain Filters either in a Knowledge Model, so they can be easily reused and managed in one place, or in a View.
for more detailed explanation you can refer below links.
https://rohit-kumar103-infosys-com.training.celonis.cloud/help/display/CIBC/Link+an+Analysis+to+a+Knowledge+Model
https://rohit-kumar103-infosys-com.training.celonis.cloud/help/display/CIBC/Views+Filters
Hope it helps.
Happy Learning.
  • May 12, 2022 11:13 AM UTC
Hi @vasco.caron11
Hope it helps.
Happy Learning.
I think @vasco.caron11  is referring to the variables and not the filters. I have the same question to so im curious sicne I did all I can but still no success.Capture
  • May 12, 2022 12:29 PM UTC
Indeed, it is just as @gay.marie.casti says, I was referring to the possibility of taking Variables that have been defined in a Knowledge Model, and using them in Studio Analyses.
We have not yet found a way to do this, but have resorted instead to creating KPIs, in the KM, that are built around these Variables, since KM KPIs are usable in Analyses.
I hope this helps somewhat
Vasco C.
  • Feb 19, 2024 6:36 PM UTC
I have the same problem, please could you share if the solution has been found? I have exactly the same problem and the documentation is not clear and there are no examples.
I want to be able to update a variable from the views and modify a KPI of the KM.
I mean, from a view I want to modify the value of a KM variable and that variable can be used in the calculation of a KPI in the same KM.
Example, from view I want to select what data I want to insert in the KM variable and then in KPI the calculation is updated with the variable that I have updated
Variable
I hope you can help me
Thank you
