Is it possible to define a display rule based on a value of another column?
  • Apr 27, 2023 10:04 AM UTC
  • 8 replies
  • 231 views
irfan.suria12
Member Spotlight
Forum|alt.badge.img+5
With display rules, I can customize visual styling for the content based on the cell value. However, I would like to use the comparator against another value.
In my specific example, I want to add priority symbols next to each PO number based on another attribute, for example the delivery date or net order value. For the latter, I want to define buckets and then map them into priorities that should be the value to compare against in the display rule.
You can think of the feature custom conditional formatting in Excel.
Is this possible?
Cheers
Irfan
Hi Irfan, thank you for your question.
Did you try adding different comparators to the same content rule ? eg comparator 1 says if step 1 then yellow, comparator 2 says if step 2 then red, etc...
That should do it because one display content rule consists of a list of comparators.
28a7b0dc-3b73-4b00-8ad8-b62f7a9149fe
Many thanks
irfan.suria12
Member Spotlight
  • Member Spotlight
  • Jun 5, 2023 6:26 AM UTC
Hi Mentor, thank you for your answer.
Could you please elaborate further? I'm not sure I understand you completely.
Do you mean that I could also use PQL or attribute IDs as comparators?
irfan.suria12
Member Spotlight
  • Member Spotlight
  • Jun 5, 2023 6:28 AM UTC
In the example on your screenshot, the display rule is not comparing against another attribute or KPI, rather than against fixed hard-coded values
  • Jun 6, 2023 12:45 PM UTC
Hi! I am also interested in this question. I have the same request what was mentioned by Irfan Suriaganda. I would like to use display rule to compare a KPI with another KPI. I tell the truth I hardly imagine such a business case when I compare a KPI with fix (harcoded) value.
As I remember this feature is available in process analytics. But I would like to use it in View.
example:
  - id: disp_rule_e2e_int_hour_01
    displayName: Display rule test
    customAttributes:
      - comparator: GREATER_THAN_OR_EQUAL
        KPI: sum_plan_effort_as_quoted
        style:
          textColor: red
          backgroundColor: black
irfan.suria12
Member Spotlight
  • Member Spotlight
  • Jun 13, 2023 10:16 AM UTC
Hi @mentor.vucit , any updates on this?
@purszki.sándo explained it very well what I am trying to achieve
  • Jun 13, 2023 8:42 PM UTC
My temporary solution was to create a new column representing the ratio of two KPIs. After that I could bind the display rule to constant numbers. The disadvantage of this is that it is an extra column and I could not color more than two KPIs within a column. example: KPI1/KPI2 <0.9 then red background color and KPI1/KPI3 > 1,2 then blue text color.
Hi @irfan.suria12
Display rules only accept static values at the moment. Does @purszki.sándo''s temporary solution worked out for you ?
irfan.suria12
Member Spotlight
  • Member Spotlight
  • Jun 15, 2023 3:29 PM UTC
Unfortunately not, as in the given example, a completely new KPI (ratio) was color coded instead of an existing KPI.
But okay, then it does not work at the moment.
