Is it possible to cancel a Studio Skill's Ongoing / Queued Executions?
  • Oct 29, 2021 8:21 AM UTC
  • 168 views
Like the Title says, I have 18 Queued Executions of a Studio Skill that have been pending for 30m
Here is a picture of the flow:Celopeers
Does anyone know how I can cancel / restart?
It was running fine when I had just a couple of columns being written to the table, I've since added a number of columns and changed the Table Name
Thank you in advance!
Best answer by stephane.multo
Hi Vasco,
It seems that manually cancelling a Skill within Studio isn't possible as of now.
However the Skill's executions should automatically cancel after 2h due to Timeout.
Also it could be noted that Action Flows should be manually cancellable when they've been launched manually.
Bonus - you may be able to work past the ongoing/queued executions by duplicating the Skill
Hi Vasco,
  • Nov 1, 2021 9:59 AM UTC
Hello Stephane,
Thank you for your reply.
They did not get cancelled due to Timeout, but they did execute at an extraordinarily slow pace, for some reason:
Celopeers
Either way, I did circumvent it by duplicating the Skill, which seemed to fix whatever the issue was!
