Insight Explorer - KPI from Knowledge Model cannot be added
  • May 27, 2026 3:33 AM UTC
  • 698 views
Vladimir.Puskaric
Level 6
Hi everyone,
I have a question relating to the Insight Explorer and look forward to your help/ advice.
In the related Knowledge Model, I have defined a KPI called Rate of transferred calls - ID =percentage_of_transferred_calls, with this PQL formula:
KPI("count_of_transferred_call_segments")
KPI("count_of_calls")
Unfortunately, this KPI does not come up on the list of Metrics that can be added to the Insight Explorer. If I search for its ID within the Insight Explorer configuration, I get the response:
No Metrics found
For additional context, count_of_transferred_call_segments has this PQL formula:
sum(
CASE
WHEN "ECHI_CASE_TABLE_Call_Data"."transferred" = '1'
AND "ECHI_CASE_TABLE_Call_Data"."disposition" = 2
AND "ECHI_CASE_TABLE_Call_Data"."outbound_call" = '0'
THEN 1
ELSE NULL
While count_of_calls has this PQL formula:
SUM (
CASE
WHEN "ECHI_CASE_TABLE_Call_Data"."disposition" = 2
AND
THEN 1
ELSE 0
I’d really appreciate your help in resolving this issue. Thanks a lot.
Vladimir
Hi Vladimir,
That pattern often does not qualify as an eligible Insight Explorer metric, even if it works fine elsewhere in Studio. Insight Explorer expects metrics to be of a supported aggregation type, and in practice it works best when the KPI formula itself is directly written in a supported form like AVG(...), SUM(...), or MEDIAN(...) with the aggregation visible at the outermost level.
Could you re-write your KPI as a single aggregated KPI and please try using that in Insights Explorer?
Thanks,
Vladimir.Puskaric
Level 6
Hi Amishee,
thanks for your response.
Not sure how to do that, given I need to divide two KPIs to get the rate. Are you able to provide help with this?
I look forward to hearing from you. Thanks.
Vladimir
Vladimir.Puskaric
Level 6
… Or will I need to wait for Celonis to start supporting divisions in Insight Explorer?
Rates/ percentages are often valuable when comparing performance between subcategories (of cases) which have very different volumes.
Vladimir
