Index sheets - Front end
  • Jun 27, 2019 11:12 AM UTC
  • 173 views
Hello All, Anyone knows how to use and what is the benefits of using index sheets on front end analysis? I tried using and seems its scanning open requests but not sure how is it working? Thanks, Kalpesh
Best answer by maximilian.kohl
Hi Kalpesh, Thank you for your request. In general, you dont need this functionality. The effect of this feature is the same as just opening each sheet in the sheet one-by-one. The Index Sheets does this in an automated manner, thereby executing all PQL queries inside all components. If the analysis contains complex queries for which the response takes more than one second, and if the query cache is activated and not full, the results for these queries will be cached, that means they will be available quicker when you open the respective sheet again. Kind requests, Max
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Sep 25, 2020 9:08 AM UTC
Hi, Im not sure what the initial question was, but is this what happens when you create a button sheet indexing? Kind regards, Joos
Hi Jos, this refers to using the Sheet Index function when right-clicking on an empty space in an analysis. image370608 20 KB Kind regards, Max
