In OLAP header and OLAP’s Fields header not able to use dollar ($)
  • Oct 29, 2020 4:30 PM UTC
  • 54 views
Hello Experts, In OLAP header and OLAPs Fields header not able to use dollar ($), When I use the ** symbol, for example, if I give **Amount then it turns as "#{Amount $}".
gabriel.okaba11
Hi Pritam,
You should be able to use the dollar sign as part of the header. Make sure you are not including symbols that refer back to the name mapping. You can simply type Amount $ (no * and no [] symbols) and you should be able to see it accordingly.
Gabe
