In Benchmarking, to apply filters using attributes in views
  • Sep 8, 2023 12:41 PM UTC
  • 102 views
Is it possible to apply filter on an attribute of a record in views
Currently I am only able to apply filter on columns of data model
Hi @Raman Silotia
Please be informed that filters need to be defined in PQL. Hence, only columns from data models can be used and not record attributes.
Thank you for your understanding.
Doruntina Kukaj
  • Oct 18, 2023 8:26 AM UTC
Ohh alright thanks Doruntina,
It would be great if Celonis adds the functionality of using record attributes in view filters, it would make more sense that way I guess
Hi @Raman Silotia
Thank you for your response.
Regarding this, you can submit a feature request through your Celonis point of contact.
  • Oct 19, 2023 6:38 AM UTC
Hi @Raman Silotia
Thanks Doruntina :)
